Clipperjay
Hey guys I'm about to purchase some 1/2" -3/4" fittings for solid copper pipe work, so whats out in the market for hard copper?
Anyone actually use copper instead of hard plastic tubes?
I have old Alphacool G1/4 13-19mm which I can't use due to being soft pipe work.
So HDC compression fittings on G1/4 would be 1/2"(13mm) ID 3/4"(19mm)OD correct?
The pipe work I've used is 15mm so 13mmID should be okay restriction not being too harsh throughout the system?
Thanks
Clip
Thanks
Clip
