Heyyo,
Hello,
I'm building a new computer from scratch. Here is almost a final version:
Intel I5 6600K (water cooling NZXT Kraken X41);
Asus Z170 Maximus VIII Ranger;
MSI R9 380 Gaming 4G;
Kingston HyperX Fury 2x 4GB 2666MHz DDR4;
1x SSD;
2x HDD;
Fractal Design Define S Window (1x front/1x rear 140mm fans).
Any other suggestions regarding this setup also welcome
Thanks
Well bud, tbh I'd recommend going another way with your build if you plan on using it for PC Gaming as a primary.
What I'm saying is... that R9 380 is quite limiting. Looking at your CPU, motherboard, GPU and RAM I'd definitely plop more money on your GPU tbh if you want the best graphics quality with performance.
Here's what I recommend changing your PC guts to:
PCPartPicker part list /
Price breakdown by merchant
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($227.99 @ B&H)
CPU Cooler: NZXT Kraken X41 106.1 CFM Liquid CPU Cooler ($99.99 @ SuperBiiz)
Motherboard: ASRock Fatal1ty Z97 Killer ATX LGA1150 Motherboard ($71.98 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory ($47.89 @ OutletPC)
Video Card: MSI Radeon R9 390X 8GB Video Card ($409.98 @ SuperBiiz)
Total: $857.83
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2015-10-20 12:51 EDT-0400
Here's why:
In PC Gaming? GPU is more important than the CPU in many games and with DirectX 12 and Vulkan 3D API's that will slowly but eventually take over in 2016? GPUs will become even MORE important as the draw calls will get moved from the CPU to the GPU... so I'd recommend spending half your budget on the GPU. I went with the MSI R9 390X Gaming Edition because it's fantastic for the price to performance and it will spank the R9 380. Here's a perfect comparision where Toms Hardware did some MSI Gaming Edition GPUs:
http://www.tomshardware.com/reviews/amd-radeon-r9-390x-r9-380-r7-370,4178-6.html
Even if you don't want to get a 390x? The R9 390 is very close in performance with a slightly lower price.
http://www.techspot.com/review/1019-radeon-r9-390x-390-380/page4.html
CPU? Intel i5-4690K. Why? It's barely slower when overclocked when you compare it to the i5-6600k but it does save you $30 and helps make up for the price difference between the R9 390X and the R9 390.
Motherboard? ASRock Z97 FATAL1TY. ASRock is a seriously underappreciated company. Their warranty is as good as the big names and they make very solid motherboards. Ther OC Formula boards have been used in the past to break CPU overclocking records too.
RAM? Gskil. They're another underrated manufacturer. Their RAM is good and carries lifetime warranty just like the rest... plus, red heatspreaders to match your build color on the motherboard and GPU. Win-win.
If you really want to keep the i5-6600k though? I'd still recommend stepping down the motherboard since you don't plan to CrossFire and step up your GPU. That Asus fancy board does help you get the best overclock you can yes... but for nearly double the price of a board that will give you comparable results? you're better off with a beefier GPU for performance. Here's what I'd recommend for your Sky Lake build:
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor ($259.99 @ B&H)
Motherboard: MSI Z170A PC MATE ATX LGA1151 Motherboard ($109.98 @ OutletPC)
Memory: G.Skill Ripjaws V Series 8GB (2 x 4GB) DDR4-2400 Memory ($47.99 @ Newegg)
Video Card: MSI Radeon R9 390 8GB Video Card ($313.98 @ Newegg)
Total: $831.93
Generated by PCPartPicker 2015-10-20 12:45 EDT-0400
To put things into price differences, here's your current build:
Motherboard: Asus MAXIMUS VIII RANGER ATX LGA1151 Motherboard ($202.98 @ Newegg)
Memory: Kingston FURY 8GB (2 x 4GB) DDR4-2400 Memory ($56.99 @ Newegg)
Video Card: MSI Radeon R9 380 4GB Video Card ($209.99 @ Newegg)
Total: $829.94
Generated by PCPartPicker 2015-10-20 12:54 EDT-0400
So my recommended build with the R9 390X?
$857.83 - $829.94 = $27.89... and your games will run a LOT better.
My Sky Lake recommended build with the R9 390?
$831.93 - $829.94 = 1.99... and your games will run a LOT better.
Of course, just my opinion tbh... but your motherboard won't generate framerate, your GPU does though. You don't really need an enthusiast motherboard unless you're trying to set records on 3DMark or going for looks over performance since their heatsinks look fantastic.
Linus Tech Tips: Premium "Gaming" Motherboards - Are They Worth it?
https://www.youtube.com/watch?v=yeuJAOVRoA0
Also, LOL at 3:40 in his video where Nyan Cat dies and falls off his monitor.
Ok... next thing... PSU's. You don't plan on CrossFire? That's fine, you can stick with a smaller PSU. I've always done a rule of thumb of 10% lower than the max Wattage rating of the PSU as a bare minimum. PSU's run hotter and less efficient drawing more power when they reach maximum load.
Let's use that first PcPartPicker list I made... estimated wattage of those parts? 457 Watts.
457 W * 110% = 502.7 Watts should be the bare minimum size... so the next size up is 550 Watts...
so that means... 457 estimate / 550 Watt PSU = estimated load of 83% on the PSU. She's well within safety rating and has room to overclock.
As for the whole 80 Plus Bronze Vs Gold? Meh, the efficiency power savings only really add up around the ten year mark... if your PSU even lives that long lol. The current standard warranty is five years... which is why I can't recommend Corsair tbh with only three year warranty on theirs.
With that in mind as well though? It's always good to look at sales... and right now EVGA are offering a $30 mail in rebate on certain PSU's bought from NCIX... so you can buy a 750W 80+ Bronze PSU that is semi-modular for the same price as regular priced 500 W PSUs which is badass.
http://pcpartpicker.com/part/evga-power-supply-110b20750vr
