See title. I have a compressor (is that an English word?) on air but it's too powerful for the job (made for spray painting cars) so I'm looking to get a weaker one - unless u have better suggestions.
I vacuum the filters and the back panel. Every now and then I'll strip it down to get rid of the dust between the radiator and fans. I use a duster on the fans and around the inside on occasion. Probably not recommended but it works.
Cheers lads! I meant I have no actual machine you plug in a wall socket with a big tank I used to use compressed air cans too but they're now about 15 quid here so I stopped.
That's exactly what I need Kaapstad!! I'll try and find one. It not being too loud helps too because that compressor I've got you can hear a block away, literally. My neighbors do not love me.
Here is what I have in my cleaning kit.
Paint Brush,
Anti static micro fiber cloth,
Pipe Cleaners,
Cotton Buds (ear buds),
Isopropyl Alcohol 99.9% (wipes or bottled),
Kitchen Towel,
A couple of hours to do some deep cleaning.
I use compressed air at a royal price I usually buy bulk like 6 cans usually last a year.
But I have paint brushes with horse hair and wooden handles due to static build up from nylon synthetic paint brushes, plus make sure any vacume cleaners have a long tube as the amount of static generated from the 2000w motors can travel down tubes LOL!
