Hi guys! First post here so, hello!
I've been trying to get advice on this for a little while using r/buildapc and things but every post I make just gets flooded with 'it sux get ryzen' over and over. Which is lovely and all but not very constructive or useful ... and from looking around here, it seems you guys are a bit more level headed
I'm moving on from a 3770k rig and my primary uses are gaming, streaming (hobby), video production/rendering (work) and programming (work).
For these reasons I've been looking for high clock speeds and a good core count. My original idea was to go for the 7820X but I decided to wait and see how TR was and honestly, I found it a bit disappointing. Sure it's amazing at multi-treaded stuff but the gaming side of it is rather average (not that I expected anything else, but I had hoped for a miracle!).
So that throws me back towards X299. The higher clock speeds and IPC give it that gaming edge. The 3770k is still a beasty gaming CPU (Mines 4.8GHz with an aio comfortably) so I want to make sure I'm upgrading that experience.
And in walks the 7820X. I was looking at the 7900X too but the £400 difference is rather large and I'm not sure I can justify that really. The lower PCI-E lanes (28) doesn't really bother me that much - I don't plan on ever going SLI so 16x is all I need for the GPU. Leaving me more than enough for one or two M.2 drives (correct me if I'm wrong here!). 8 cores 16 threads should be more than enough for gaming + streaming with a good frame rate. I have a G-Sync 3440x1440 widescreen so like my juicy frames.
I have a GTX 1080 + a load of SSDs/HDDs + EVGA 850 Supernova PSU + Phantex Enthoo Evolv that will be coming across, so with that in mind, this is what I am planning on purchasing: Screenshot of purchase list from overclockers
Couldn't find all the parts on pcpartpicker hence the screenshot from overclockers.co.uk wishlist. Hope that is alright
There is a slightly faster SSD for another £150 but for the 200mb/s increase in read/write that doesn't seem worth it. Seems more a case of they're just the top top top chips so they charge a premium for them if you reeeaally want them.
As for the RAM - there are also slightly faster kits but is that really necessary? I'm coming from the old times where RAM speed doesn't really effect things that much. I've heard mixed things about DDR4.
I'm off out to a BBQ for the next few hours so won't be around to reply quickly - but I'll be back later and interested to know your thoughts! If I missed anything or you want any more info - let me know.
Thanks in advance, see you later ^_^
