Cant remember XD.At idle they get to about 40 degrees but my H80 is in pull push ATM because im just trying things out..Will run a stress test tommorow and then try push/pull.
That was the solid temp after 30 minutes of Prime95 with all the cores at 100%. I was using a Push/pull on a Corsair H80 with the second fan speed thing on the block. At idle i sit at 28 degrees with the lowest fan speed profile mcthingy on the block
