I'm using a Coolermaster Wavemaster case (so i'm pretty limited to the size of the cooler i can use)
The dimensions of it are: L540 x W198 x H458 mm
I'm running a Q6600 (older one) on a Gigabyte P35-DS4, and i was wondering if anyone could recommend a good cooler. I'm currently using the stock cooler which is pretty crap as it even has an aluminium baseplate on the heatsink
Thanks!
Matt
Thanks!
Matt
