What color should i get in the SP120's Advice on a high density/intensity UV set up?
Xrqute
View original post (with images)
What color should i get in the SP120's at first i wanted Blue and White. But since the tube is so much darked then i expect Im now thinking maybe purple/white or purple/blue? What do you guys think?
Advice on a high density/intensity UV set up of either LED's or Cathodes?
Take a look at the latest Singularity Computers build log on YouTube, they found some really strong high density UV led strips and you can see what they look like. The one with the purple pastel coolant.
Or you could take a leaf out of L3Ps designs and pair a blue led strip with a UV led strip for a really striking effect - search for L3P D3sk to see some glowy loveliness.
