AMD 64 3000+ NewCastle, Gainward 6800 GT, 2 x 512MB Corsair 3200, (dont know if any of this is relavent but heres the other components inside: Seagate Barricuda 200GB S-ATA, IBM Deskstar 170GB IDE, Audigy 2 ZS, Pioneer 109 DVD+-RW, Samsung SM352-B CD-RW/DVD-ROM. And i have just installed a Ryanpower 2 PSU). I dont know if you've read any of my other posts recently but i also have a situation with the Mach2 GT controller.if you read my other posts (there in the Mach 2 section of the forum).Is it because my unit is currently running R134a refrigent, that my cpu temps sit between 11 and 25 degree's C ? i am waiting for phil to send me up some dialetic grease so i can rebuild the evaporator around the cpu to see if i can make things cool better.
- Update -
i have just got back from uni, and my pc sits on my desk, and it just clunked at me, reading back on this post i think someone made a comment on this meaning the compressor can still do alot more workload or something. is that right? or was it that the compressor wasnt screwed tight enough to the bottom of the case?
- update -
/me slaps fatty.
- update -
Ok, i am using a perspex case, in which case where the back of the motherboard is, where the back plate with the thermosensor in for the mach II head, since putting in the new controller yesterday, and well putting a cable tie on the tube just to stop the see-thru plastic thingy (shrowd? or summit) from thraying i have noticed that the back panel - the one mention at the begining of this paragraph has been extremely cold - it use to get quite warm, if its cold thats a good sign right? btw, for a Mach II ST running a GT controller i am getting -50 degree's C on the evap head with 100% load on the cpu!! i take it thats good too???
