WC Loop for 2500K and 2x Gtx570 SLI?
Badelhas
Hello community!
How much would I spend to do a Watercooling loop to my system? The CPU is already Overclocked to 4.3Ghz and the GPU´s are Overclocked to 850+2050, stock voltage. My objective would be to make the system quieter, as well looking cooler.
Thanks in advance.
Cheers
Where abouts are you? prices vary from the EU to the US to India to Australia to where ever else so location will help so you dont get answers in £ or $ if your in AUS or something as the price for X setup using the current exchange rates is rarely the same in a different region. (also if your not in the UK/EU/US/Canada/Aus you may want to post the website you would probably be buying from for people to draw prices from.)
Are the 570 reference cards? if not you will probably find it hard to find blocks for them.
You will probably need something along the lines of a 360mm + 240mm radiator to get a worth while temp AND noise improvement tho.
