maverik-sg1
Using a chilly1 or similar on your mach unit is great - better cooling under load - easy mounting, less risk of condensation.
However - with the emergence of Conroe Intel motherboards will be back in favour, most of which have the capcitors situated closer to the socket than any other motherboard. For normal mach or vapochill heads this is not a problem - but the unique mounting of chilly style heads it creates a problem.
Not really been an issue before, mainly cause Intel have not been competitive in the enthusiast market.
The idea of this thread is to post your aolutions to this problem with supporting pics where possible.
My own thoughts are to use a mach mounting kit - Drilling through the top plate (so chilly bolts can be used), discard the metal head mount and possibly cutting away some of the plastic on the top mount to enure the chilly head makes full contact with the cpu.
The option to use seal string to seal teh mount to the board is still an option, although a thicker neoprene gasket will allow for the head to be raised high enought for the chilly 'donut' to clear the caps completely - of coure this will mean trimming the chilly donut too (as to avoid excessive compression and subsequent 'bulging' of the neoprene seal).
I don't have picks as this is just my thoughts (I dont have an Intel system at present).
Post your thoughts, ideas or proven techniques here.
Mav
Mav
