trawetSluaP
Member
Hi all,
Having a little difficulty with this.
I would like to mount a 360mm Rad onto the side mounted rad bracket inside the case and mount The D5 combo beside it, however, there isn't an actual mounting point on the bracket for the pump/res and wondered if your kind people have any suggestions I could try?
Just to clarify I don't want to mod the case or be drilling into it etc.
Dimensions of the bracket are on pages 24 and 25 here -
http://www.phanteks.com/assets/manuals/PH-ES916E.pdf
Thanks,
Paul
Thanks,
Paul
