Watercooling Thermometer
Aqua computer are massive mate they are a german company and make blocks, and some of the most advanced fan/pump controllers. The first one on the list is not any different than using a coupler its totally sealed. I would have no issues using it. Its also in-line so its more subtle than stop cap style where you would need to you a T fitting.
Don't forget their AMS rads!
I have a bitspower one. Never had issues or leak.
I was thinking about that but I really have no place to put it. (Not that exact one.)
I thought the first one looked best myself. I knew I have heard of aqua cooling but I had never used their products before. Its good to know that its a good company.
I will probably be going with those thermometers in that case. Unless someone posts something far superior.
Thanks a lot for your replies!
EDIT:
I am planning to use this sensor with the Maximus V I will be getting. Will the sensor work with the board?
I would think so mate the thermometer is just a generic thermometer at end of the day and the spec says it can.
Are you going to dynamic adjust your fan speeds?
Yes. Either by using Corsair link or the Asus software. I have spent quite a lot on PWM fans for this build.
I might get two thermometers just to measure IN/Out temps after the water blocks. And then have a standard thermometer outside the case to measure ambient temp.
