I'm looking at going WC but do not have time currently. I have read many tutorials finding out the basics explained in many ways but some questions I cannot answer unless I have the kit here so measurements are my best friend.
120mm x 180mm x 170mm is the space where I intend to site the reservoir, pump, radiator attacment (i'll explain later) and tubing splitters. For blocks I have a cunning plan and damn the expense (i probably will for one reason or another). I only plan to do the CPU and the SLi GPUs (for the moment at least). Swiftech MCW6500-T1 TEC & WC block for the CPU and for the GPU I was looking at some EK full board blocks this one and this one. What in gods holy name is the difference between these blocks aside from not being able to see the water (or other liquid) flowing through it. They are both ready for SLi so I can regain some space (and airflow).
The reservoir and pump i would prefer to have pre-made (pump in res) but pre-assembled may have to suffice. I'm more worried about pump ability than res size because of what i plan to run (explained soon). A simple res and pump combo mean i can fabricate a TEC cooled res from my old electric fridge. Nothing fancy like just whip off TEC and attach (somehow) to the res (or DIY made res to same spec).
Radiator attacment will be on the side of the case near the front. I'm gonna weld on some bits (father-in-law is sheet metal worker and has been for over 50 years) so i can remove the side panel with hassle still. I also intend to fit a full 360mm radiator to keep the temps down. I've read about the ThermoChill PA120.3 and I am impressed but can't help thinking one of the others may help out more.
In the recent PCformat magazines there has been a case modder guy doing some watercooling as well as other bits. He had some tube splitters but not 2-to-1 but 3-to-1 and they were metal too. This got me thinking about my plan i had originally planned to serial attach rad-block-rad-block-rad-block but if i could split the flow i could use one behemoth rad and three separate loops (or more
I have a an aluminium racing radiator in my car (modified
) and use OAT coolant (as recommend by my friend who works for BMW F1 team) but I am wondering if this would be good in my PC as it would stop fungal growth and cools over 15% better than deionised water and does not corrode the radiator.
Thats my plan and unfortunately here are my questions.
- Swiftech block, good idea?
- The GPU EK blocks what actually is the difference?
- What are my pump in res options?
- Is there a pre-fabricated pump-res combo you would recommend?
- Are TEC cooled res' available?
- If Yes will they work as I hope to do it?
- Will my radiator shift enough heat from my system?
- Where do I find tube separators like that guy?
- Would OAT racing coolant be good in a PC WC setup?
