Hi Folks
I am currently planning my new build and needed a little advice on watercooling.
I plan on a socket 2011 build with 2 way x-fire/SLI config, I plan on definately overclocking the CPU, and probably overclocking the GPU's.
I really wanted, if possible to keep to a single loop config, and wondered if either a 360mm Rad or a 480 mm Rad would be sufficient for this?
Many thanks for your help
