FragTek
Note: I did not write this, this was taken from another forum and credit is to be given to AngryAlpaca for the time spent on this one... I'll take the reps for it though
Also note that I don't endorse some of the same components or methods that this person talks about, but it's a great general guide to basic watercooling.
P.S. You don't need a fuckin' waste of sperm reservoir in a high performance watercooling setup
I'm bored, and I know that most people are sick of answering the same answer to the same question repeatedly. First I will start with the basics, and then I will move on to equipment. If you just want to know what to buy, scroll to the very bottom of this guide.
Water Cooling: The Basics
Processors are getting hotter and hotter, heatsinks are getting larger and one can use heat pipes to spread the heat out more, to get more efficiency out of your heat sink by utilizing all of the surface area, rather than a little bit at the bottom, or, water cooling. Water cooling is, as you may have guessed, the use of water to cool your processor. This offers several advantages, the first being that you can get the heat moving as fast as you want, much faster than with copper, diamond, or even heat pipes, by increasing the flow rate. It also allows you to use a large radiator, and that has a much higher surface area to dissipate heat from than a heat sink could possibly have. It also lets you use larger fans that move more air with a lot less noise. Unfortunately, nothing is perfect. Water cooling will usually cost more than air cooling, and take up a great deal more room.
Okay, so now we go into the actual act of water cooling. Basically, you have a water block on the CPU that absorbs heat, and passes it onto the water. Most water blocks are designed in such a way that a lot of heat is transferred to the water, with the use of mazes, that channel the water around, fins or pins to increase turbulence and surface area, or, more recently jet impingement. To move water through this water block at a fair velocity we use a pump. Using no pump is possible and allowing just convection to take place is possible, but it's more difficult and a far worse cooler. A pump uses an electric motor to spin an impeller that forces the water through the tubing, and into the water block where the heat is absorbed by the water. Now that we’ve got the heat in the water, we must remove it. We do this with the use of a radiator, and we’ll go into the specifics later. With a radiator, however, the natural convection of the heat isn’t enough for most users, so we connect a fan. 120mm fans can be used, and these cut down on noise while boosting airflow as compared to smaller fans. A fan has a dead spot and does not cover the whole of most radiators so a shroud should be used. Once again, we’ll go into this later. After the radiator, the water goes on back to the water block, and begins the cycle again. It doesn’t sound so hard, does it?
Water Blocks:
This is a chunk of metal that goes on top of your CPU. Its only purpose is to transfer heat from the CPU to the water and is probably the most important part of the system. If you want to upgrade your watercooling then this is the thing to change. They are designed to get optimal heat transfer, and move the heat from the CPU to the water in the most effective way possible. Older style blocks used mazing, or routing the water, so it spends more time in the block and has more surface area, or pins, which increase turbulence and heat transfer area as well. However, mazes were pushed to the lower end with the release of the White Water, which utilizes jet impingement and mini fins. Jet impingement is the use of a conduit of water that is decreased in size, a restriction, to accelerate the water to fairly high speeds, so the water hits the base at a fairly high speed, reducing the boundary layer (a microscopic gap between the copper and the water, caused by imperfect copper and the surface tension of water) and carries the heat away quite effectively. Mini fins are tiny fins in the base of the block made to increase both turbulence and surface area. Pins (and mazing, to an extent) have recently made a comeback with the introduction of Swiftech's MCW 6000/6002, which utilizes a jet above the the centre of the waterblock (which sits right over the die) and then has 281 pins inside, in addition to a u-shaped piece of metal that makes the water go the long way around, rather than straight to the outlet, and I imagine that pins will start to be incorporated into other waterblocks.
The very best water block that is available is the MCW 6000. It may look bland, but it offers the best performance and one of the best prices ($40). The MCW 6000 (3/8" barbs) offers slightly better performance than the 6002 (1/2" barbs.) In the UK or Europe the TDX is probably the best that is available now, as it is easy to use and fairly good, although the MCW 6002. The RBX is similar but is harder to mount and use, as it has 3 barbs, so any performance gains are essentially lost. The WW is slightly better than both the TDX and RBX but once again, has three barbs. This block is a viable option in the UK and Europe, as well as the RBX, due to a lack of availability of the 6000 series (the MCW 6000 series is becoming much more widely available in the UK). There are many other blocks that offer comparable performance, but with the low price, high performance, and ease of use of these blocks, the others are probably not worth taking a look at.
If your water block has 3 barbs, the water goes in the middle, and out the sides, and these come with a Y fitting, that you use to reconnect those barbs.
Look here or here to check for water block ratings. These sites are accurate. Lower C/W is better, along with a lower pressure drop.
Chipset Water blocks: These are, as the name implies, blocks for your chipset. I don't suggest these, due to a restriction in flow, and no increased overclock (Bill Adams' work - there's also no increased overclock with watercooled RAM), but if you are dead set on one, I suggest the DD Maze 4 NB block, as it has a very low pressure drop and good enough performance.
GPU block: This is a block for your video card. Unlike the chipset block, this one does matter, although still not as much as the CPU block. The Swiftech MCW50 and the DD Maze 4 are both about the same performance, so let other factors be your guide (tubing size, compatibility, cost, even looks), but there is a lack of reliable testing of the three so I have to make this advice based only upon what can be observed of the other blocks in the series (CPU and NB). Dangerden's 6800 block covers your GPU with a Maze 4 and also watercools your video RAM, but the RAM overclock does not increase, the pressure drop of the block increases substantially and as does the price, for no gain whatsoever.
Pumps:
These move your water through your tubing. I’m not sure about the specifics of the inner workings of these, but it involves a spinning magnet and an impeller, which actually moves the water. Pumps have three ratings: Flow; measured at 0’ head resistance, due to this it has very little bearing on the performance of the pump, but the higher the better anyway. Head pressure; measured in feet H2O or metres H2O. This is the most important number, as we have got a lot of resistance in our systems. Note that the amount of tubing is not how pressure drop is measured - 6 feet of tubing has about 6 inches (at 1GPM) of pressure drop, whereas a typical waterblock has about 1.5 feet (at 1GPM) of pressure drop. The higher the pressure, the better it is. We’ve also got heat; this is the amount of energy the pump draws, and it transfers most (50-90%, depending on the pump) of the drawn energy to the water.
I think I’ll make this generalization right now. ALL standard pumps perform about the same. By standard, I mean pretty much all pumps with flow between 180GPH and 5 feet pressure to ~400GPH and 12 feet pressure. In a typical system, consisting of a Procore and an MCW 6002, there will be NO measurable difference between these pumps. Temperature changes are more noticeable with less flow than with more flow - decreasing your flow by 50% hurts it more than increasing the flow by 50% helps. The differences in pump temperatures get larger with more blocks, and more resistance, but they’re still very small.
*Note that I have dropped my recommendation of the Mag 3, due to the leaks, noise and size.
*Note that I have dropped my recommendation of the C-Systems CSP 750 due to many failures.
*Note that I have largely dropped my recommendation of Iwaki pumps, due to a large size and cost. They are very good if you've got a lot of room and money. I haven't heard of any of these failing.
The MCP 350 or the Dangerden DDC is the best pump out right now. I say this because it offers decent performance, a 50,000 hour life, quiet operation, and a very small package (2.4" x 2.4" x 1.5"). This costs about $75 right now. A couple of failures have been noted, but I think that this will be dealt with rather quickly. New pumps have problems, but the manufacturer has a very good history.
The Danger Den DD-D4 (new revision out, quieter and weaker than old one) or the MCP 650 is a high performance pump, with flow equalling that of the Mag 3, but with about ½ the heat. It is 12VDC, and sucks up to 1.5 amps. Form your own opinion about that. This pump is now fairly quiet (if you are watercooling for quiet, do NOT get this), and has a life span of 50,000 hours mean time before failure, the best in the industry, and costs 75 dollars at the moment. I haven't heard of any of these failing, except for noise.
The Aquaextreme 50-Z is about on par with the D4 for performance, but has a higher failure rate, and only had about a 20,000 hour lifespan when Swiftech carried it, but it seems to have improved now, although no lifespan is available.
The Eheim 1250 is a very high quality pump, albeit with worse performance (once again, it doesn’t matter) than the other options. It runs at about 60 dollars, and is quiet. I suggest this pump for longevity, or in a situation that any minor failure is catastrophic. I have never heard of ANY problem with this pump.
The Hydor L30 is small, outperforms the Eheim 1250 (once again, does not matter because the difference between the two is so small) and is fairly quiet. A few problems have been reported with this pump, but they've been minor. It sells for around 50 dollars.
The Hydor L20 falls into a bargain category with few setbacks. This is a small, quiet, AC pump costing about $40. I'd suggest this is budget is important. I can't recall any failures.
The Via Aqua 1300 is the cheapest pump out there. It is high heat, noisy, and low quality. The only reason I would advise this pump is if price is a serious issue.
Radiators:
Radiators are used to dissipate heat. A radiator usually consists of a large amount of very small, flat tubes, with fins attached to increase heat dissipation. There are used in cars, for the main radiator, and the heater core. The heater core is used to heat the interior of the vehicle while the main radiator is used to cool the engine. This is the best kind of radiator, (I, and many others, refer to this kind of radiator as a heater core style radiator) but there are two others. The main alternative radiator type is the winding tube radiator. It involves a winding tube, with fins attached to increase heat dissipation. These are generally used in phase change coolers, where the objective is to get the liquid as cool as possible, rather than getting as much liquid as possible fairly cool, and aren’t very good for our purposes. They restrict flow a lot, and are usually more expensive than heater cores, and don’t dissipate the heat as effectively. The stacked plate radiator is built very similar to the heater core style radiator, but uses wide, flat tubes as the primary heat dissipation things, sometimes with fins between them, rather than using the fins as the main way to dissipate the heat. It seems that these would as good as heater cores at cooling, but due to availability and price concerns, these aren’t used.
The heater core from an ’86 Chevette is a common choice due to its low price and small size. It has very good performance, low pressure drop, and a damned good price (Around 20 dollars in an auto parts store.) It does, though, have one 5/8” barb, and one ¾” barb, so you have to change them out, or stretch your tubing over it. The ¾” one will be tough to stretch your tubing over. You can buy a shroud already made from Dtek for this radiator. If you don’t want to mod the radiator yourself, you can just buy a Danger Den heater core for 12 dollars more. This is about 7X6”, so it won’t perfectly fit where a 120mm fan would fit. Dtek now has a radiator out that is about 7"*5" which would be a better fit in most cases. A better choice than either of those, though, would be a single pass heater core from a ’76 Chevy truck without air conditioning, but it is much larger (12”X6”) and slightly more expensive. Also, you cannot buy a shroud for it already made. This has a list of all the heater cores, one arranged by length, and one by width. For the car references, one is arranged by core number, and the other by model name.
Now, there are also the made-for-PC options. The Black Ice Extreme is the most commonly used of these. It fits where a 120mm fan fits, and fits a 120mm fan without an aftermarket shroud (shrouds are still good.) Its performance is worse, by a fairly large margin, than the heater core (2-4C), but it costs a lot more, and restricts flow more. The BIX2 is just slightly worse than the heater core, and is much bigger. Black Ices also come in an 80mm size, and a 160X80mm size, but these are probably below your desired level of performance There are also the Thermochills. They come in a bunch of sizes: 80mm (80.1), 92mm (92.1), 120mm (120.1), 240X120mm (120.2), and 360X120mm (120.3). The 120.3 outperforms the standard heater core, but I doubt it outperforms the 10X6 single pass core. (There has been no good testing done, but assumptions can be made from other testing.)
The Black Ice Pro outperforms the Black Ice Extreme and the Thermochill 120.1 with all but very high powered fans (about 4000 RPM), and likewise, the BIP II outperforms the BIX II and the Thermochill 120.2 with all but very high powered fans.
Do NOT buy radiators smaller than 120X120. That is just high temperatures, wasted money, and a lot of frustration waiting to happen. Do NOT buy a winding tube radiator. Once again, a bad cooler, and really restrictive...
Modding a Heater Core to Fit your Tubing: Big thanks to bswitt for this basic modding guide.
Shrouds: Shrouds are used to attach the fan to the radiator, and to distance the fan from the radiator as well. This enhances airflow, evening it out across the core and slightly increasing it, and reduces noise noticeably. You want one that spaces the fan at least 1” (1.12" being preferable) away, and, naturally, it should fit the core tightly. If you have a DD heater core or a heater core from an '86 Chevetter of the same size, this could be useful: http://www.overclockers.com/tips1138/ You can also buy 12 dollar shrouds from dangerden, but they offer no improvement in performance or noise.
Fans: Fans use a DC motor in the middle of the fan, with blades on the outside to move air. You want 120mm fans, or larger, because they don’t have to rotate very quickly to move as much air. Basically, get the fan that moves the most air for your noise tolerance. 70CFM should be considered a minimum air movement speed, and below that performance suffers. If noise is a really big issue to you you may want to consider going well below that anyway.
Filling and Bleeding the System: There are two main ways to fill/bleed your system, the reservoir, and the teeline. A reservoir is a large holding tank for water, and it usually has a place in which to put the water. The easiest way to fill and bleed the system, but it consumes space, and costs money. A teeline is simply a tee somewhere in your system, with a long piece of straight tubing sticking out the top. This is cheap, and saves space. I advise a reservoir if you have the space.
If you don't want to submerge your pump, you can either use a PVC reservoir or a bay reservoir, which comes in multiple sizes and configurations. You want one with a divider in the middle so less air is sucked back into the system. Submerging your pump improves your flow, but there are no commercial options, so the best method is to put it in a small Tupperware container, and then fix it up so it can close.
Tubing: This is what the water flows through. Larger ID is better, but ½” is standard, so it is easiest. You want thick walled tubing (1/8”, ¾” OD for ½” tubing) to avoid kinking.
Tygon is the preferred type of tubing, but it offers very little advantage for its cut throat price, of around $2.60 per foot. Clearflex 60 is next, very similar to Tygon, a little less flexible and stretchy, but it shouldn’t be a problem. Next in line is tubing from the good ol’ Home Depot. Look at the tubing there, and make sure it isn’t squished, or pre-kinked. It is cheap, and easy to get, although it does not bend as well as the other two.
Clamps: These are NOT optional. Put these on every barb, and prevent leaks long before they start. There are two kinds, these being, steel worm drive, and nylon hose clamps. Steel worm drive clamps are tightened with a screwdriver, are durable, and hold very well. The nylon hose clamps are put on with pliers, are plastic, and hold well enough. I advise buying steel worm drive clamps, available at Home Depot.
Cooling Fluid: For best heat transfer/heat capacity, nothing beats pure water. However, there is probably a good chance that you have aluminum (even anodized needs it) or a possibility for biological growth, so you must add an additive. Swiftech HydrX is probably the best choice out there, although it is expensive, so antifreeze is a very good alternative. If you have no aluminum in your system, 10% is fine, but if you have some anodized aluminum ~25% is recommended.
Kits are bad news. If you can customize the kit, with good components, and it will be cheaper, go for it. The Flowmaster XT is the best example of this.
Real reasons not to buy a kit:
1. The best kit is only as good as the best aircooling.
2. They are expensive for what you get. In fact, they're just plain expensive.
3. Very little upgradeability. If you decide you want to switch to a MCW 6000, or a better radiator, you will have to change everything else.
4. This is an extension of 3. They come with crappy parts. No part of the system is better than the parts you could get custom.
5. Some of them are rather loud.
6. Some of them require installation anyway! (Come on, people,where's the advantage?)
The Corsair COOL is as good as a custom with a 120mm radiator (systems with heater cores outperform it) and is available at http://www.markonecomputers.com/product.asp?pf_id=Corsair_Cool_001#des This contains all of the best parts, except a BIP instead of a noticeably better heater core.
What to buy:
For those of you too lazy to make your own decision, here's my advice that I would give you in a thread.
Cheap: Via Aqua 1300 ($20) (You might as well go for the Mag 3, for 15 bucks more), TC-4 ($25), Heater core (~$20), Tupperware for shroud and reservoir, Home Depot tubing, 120mm fan (~$10), and hose clamps. This may be above your budget, which most people put at around 100 dollars for a cheap watercooling, but, spending the extra 20 or 30 bucks now will be worth it.
Good: Mag 3 ($40) or the DD D4 pump $75, MCW 6002 ($43) heater core (~$20 [local auto parts shop, see the excel file far above]) or DD heater core ($30) shroud ($1 or $12), Clearflex 60, 120mm fan (~$10 [your choice]), and hose clamps.
These are just general guidelines, some of you may like to cheap out on tubing, but go crazy on the pump, or do some such thing.
That's pretty much all there is to it. If I made any errors, or omissions, do not be afraid to let me know.
If you want to get a more advanced understanding of water cooling, check this site: http://thermal-management-testing.com/ and read BillA’s comments about testing, and water cooling in general. Very informative.
Water Blocks:
Pumps:
Radiators:
What to buy:
