Watercooling-Alternative for Noctua NH-D14
You can strip (most of) those down if front look is too ugly to you. For that reason, i would say bay res are for noobs.
If you mean one with "own maind", then im with you.
Funny you say Corsair PSU, as i have bean trying to remember RMA my AX1200 (for noice), but its getting old and shiping cost to RMA to corsair from Finland.
Yep AX1200 fan spins (and should so) all time i know now and so, i hold it and take it from my back.
Fan controllers arent needed though when there's a cleaner alternative - ie - resistors. Controllers just add unnecessary, unsightly cables.
As for the bay res - I'm not so much against them as they make things easier as tube reservoirs are a little harder to mount and stuff. Especially as the bar reservoirs allow for you to put pumps and everything in them too. If it does bother you that much, you could always drill new holes in the side of the optical bays, mount the res 20mm further back and leave the plain look of the case on.
Thanks for the laugh of the night! :D
Clearly WE have seen them all and any other then one case cant hide them, if you take the time.
I have ordered extensions for my PSU cables and i put loss part of it same place i would put controller cables, hiden from air flow (not from eye).
In my maind you dont need any res at all, so it just more tube(inside case if that matter) to it and any pump that has direct connection to bay makes noice, so it's out anyway from many users.
Sorry for OT.
