CalVic
Member
Heya everyone,
Just a quick question regarding airflow when using watercooling, I'm currently using a H100i in Pull configuration inside a Corsair Carbide Air 540.
Here's a diagram of what my current setup:
As you can see, I have all the case fans as intake to feed the H100i fresh air and the pull fans as an exhaust. Is this correct?
Or should the rear fan be best left as an exhaust so that it doesn't disrupt the flow of air from the two front intakes?
Cheers!
Cheers!
