Waterblock for 8600GT ?
Sprite
Any waterblocks for the 8600 series ? Will waterblocks for the 7600GT work for the 8600GT ?
Cheers :worship:
(Sorry for all the threads lately as well :/)
Well I was also looking for a specific 8600 waterblock but couldn't find any. Meanwhile I just used the zalman waterblock that I had on my 7800 and there is no problem... same fixation patern etc...
So I decided to buy the DD Maze5 to make my new build and hopefully it will fit the same way.
So unless you are looking for a full cover waterblock I suppose any nvidia compatible GPU waterblock should do.
I will let you know about the DD Maze5 as soon as I got it, should be ina couple of days!
Zalman blocks=death by corrosion.
I'm not sure if the MCW60 fits or not, but EK makes a 8600 block, not sure if it fits the GT.
I have been running zalman GPU, CPU, NB watertblocks for more than year and I never faced corrosion...
but thanks for the info about the EK 8600 block, Too bad they didn't have it 10 days ago when I ordered my WC stuff :(... Maybe I will change my DD Maze5 for this one!
