water revised, new pics!!
BAcon
Here we go, got my system updated and re worked, here it is in all its glory
storm G4
silverprop HL
AQX 50z pump with oversized fittings (1/2" ID, 5/8" OD)
120.3 with 1 inch stand off
panaflow M1's
tygon r1000
oversized t piece (1/2" ID)
DD fillport
http://img.photobucket.com/albums/v218/mikejbry/IMG_0718.jpg
http://img.photobucket.com/albums/v218/mikejbry/IMG_0730.jpg
http://img.photobucket.com/albums/v218/mikejbry/IMG_0717.jpg
im crap with a cam but it gives you a good idea
Very nice, how is the G4 doing out of interest? I cant wait to get my hands on the G5's.. I'm also probably going to doing the Silverprops..
Looks good mate :)
Any chance you took a pic of the storm before it went in?
Very smart :)
Just need to braid those PSU wires :p
G4 is good, cant say i have had any specialist equip to compare to the 6002
but idle at stock in warm room with case side on is 32C load 38C
at 311x9 on 1.65v (a fair amount of heat) its 34C idle and 48C load
so a few degrees better than the 6002, id like to try 2 modded swifty mcp350's to see if the extra pressure would help the flow through my blocks, as both are very restrictive in comparison to alternative blocks
phil you will love the HL, defo get them in if you can, you'll make a packet
x850xtpe 641/600 (no ram sinks as the tape was ****e and fell off) 28C idle 32C load with case side off, not sure with case side on temps are as i killed it since rerouting to be able to shut my case door
sorry firelord i didnt, i actually have larger ID barbs to put onto the G4, just didnt get around to it when i rerouted, next time i drain it i will tho
Mike
Firelord said:
Looks good mate :)
Very smart :)
no i didnt sorry, i have a black braid kit just havent had time / cudnt really be assed yet
and no i didnt use the x850xtpe on air, straight to water
Very nice mate, my rig tubing looks a complete state in comparison to that :)
Gonna have to see if I can get me a P4 mount for my Cascade SS and get my Northy on water, see if it looks any better than my Athlon rig
Andy
Looks good anyway d00d :)
I know what you mean bout time and braiding it takes fricking ages!
Nice simple loop :) I like the fan over the RAM too :)
Nice simple loop
thanks, id like to say that was my idea using the G4's many holes for a fan over me ram but it wasnt
still a good idea tho, keeps my voltage reg's at about 35C load instead of going up to 50C
im quite partial to my thumbnuts as well, much nicer than the normal method of securing the G4 , iv also got thumbnuts coming for the HL, but the store only sent one,see if you can spot it in my blurry pics (these were again a tip from a mate)
Dont worry fella - the molex tools will be with you soon ;)
Phil Stanbridge said:
:mad:
:mad:
Me goes off and counts his molex tool stock.
Sorry Phil mate,
I told you on msn i'd ordered one just before i knew you were selling them. (Your cheaper BTW than the "other" place)
Bacon lent me his 120mm holesaw so it's only fair i lend him the molex tools ;)
