Finally water rig sorted **pics inside**
BAcon
ok got it all setup finally...*** AQX 50z came DOA :rolleyes: so is off back to the US anytime soon, in the meantime managed to find a brand new unused mcp600 rev2 for £35inc (exact same pump as the AQX) so am now using that instead
here are some pics for you all of my finished rig, bearing in mind it has now fully blead and there are no bubbles on the Tline tube
ok
and with case door off
and some other pics if your interested
closer with side off
6002
pump
close
rad barbs
side view again
front
pump close
Thats a few of them, cpu temp is good it seems, 35C idle and hits 42C load (stock volts)
if i up to 1.8v it hits a massive 48C hehe, nice and cool ;) tho with the heating on which i never use it can go to 50C (the chick needs the heating on as she gets cold) eh whats cold lol
Gpu needs a remount as temps are about 15C over what they should be, still cooler than air tho lol, but will remount later on
what do you think?
nice work mate, reasonably tidy in there - with the pump screwed down on to the chassis do you notice any vibration or rattles at all or is it silent apart from the rad fans?
I like it. I don't quite fully understand the T line's but I will have to investigate since I will be adding GPU water cooling to my rig. But that is great, I like it alot.
Thats very neatly executed mate, I like it, well done. Is that one of those lighted on switches fitted into the top of the case?
I 'think' it's a fill port for the T-line isn't it? Don't quote me on it though.
yeh it s fillport curtesy (sp) of phil
it has a neoprene pad on the bottom so when secured to the case is inaudible, case fans and rad fans are what can be heard, but they all are on controllers so isnt a problem when i need it to be quiet
the panaflows at 7v are fairly quiet and push a nice amount of air
i remounted the silverprop HL yesterday and got perfect contact, 37C idle and 42C load at 456/1.17 stock bios, so have room with a 1.4v bios
im guna have a shuffle soon as i have 3 Storm G4's coming, obviousl tnot all for me but when i drain the system ill reroute a few things
im going to try and fit the Tline near the rad outlet and reverse the fans to blowing inwards and front fans to exhaust. Should have the best airflow poss then.
have a black cable braiding kit ready to use as well then when thats done ill make a proper job of hiding wires
Dont look that bad now! Trouble with these high end PSUs is they have nuff connectors to power everything up twice just about - "more going spare than a nurse's hen night"
Anywayz, looking forward to see final result
sw
Good a reason as any to go SLI :D
name='Wingz said:
Bacon if you want you can come to the Overclockers Anonymous Meetings with me
[img']http://www.pclincs.co.uk/Forums/images/smilies/1zhelp.gif[/img]
wahey a councilling buddy, but remember bob had bitch tits (gotta love fight club) :D
