GamerGirlAlice
would it be hard to do a water retrofit on my evga p55 ftw 200 system. my system isnt very fancy at all, i want to get maybe a 500 series evga hydro card water cooling components for a single loop system. my pc is a Intel I7 860 @ 2.80GHz with 4GB of ram on a EVGA P55 FTW 200 motherboard. the only part im 95% sure i want for water cooling is a Fusion Dual Bay Reservoir by FrozenQ. wanting to do a uv black and blue build because i love how it looks with corsair. other then the reservoir im not sure the best way to build it. a good question what would be the best pump, 360 rad, tubing, and fan combo that keeps it all mounted inside my corsair 800d.
i don't want it to complicated but figured a simple layout. reservoir drops to t fitting at bottom of case going to pump and release for drain tube. then up to the gpu and the cpu. then threw the rad to another t fitting with a way to fill it and back to the reservoir. im thinking of getting a lot of my parts from the frozen cpu website. reason im thinking there is they can also sleeve me a new psu that is uv reactive like the tubing or fluid.
eventually id like to rebuild it with a asus z68 platform. but i think my p55 is okie other then a bad power supply grapics card and needs way better cooling. so i think black and blue would be a awesome look in a corsair/evga setup.
i just need help filling in the blank spots, so any advice is appreciated, especially if my p55 is a lost cause and should go z68.
ps im a handicapped girl just shy of being paralyzed living on a tight full disability income. so best bang for the buck is what i am looking for.
