Hi i need a new cooler and wanted water cooling want to get this kit
http://www.specialtech.co.uk/spshop...aterCooling-Kit--RS-Series-Kit-pid-12136.html
now i know this is good as tom reviewed it but if i added a gpu block into the loop would the 120mm rad be ok if nothing was over clocked much as say this as my current cooler has gone wrong and my case atm wont take any more than a 120mm rad and my gpu makes loads of noise.
so my plan was to get this kit and a gpu block then cool both on the 120mm rad then when i could get a better case and get a 240mm rad and add into it so then i could OC more.
the 120mm on its own would be temp but would it work or would everything get to hot?
