AlienALX
Well-known member
You'll need to have been into water cooling about a decade ago
Hi all. Some one has very kindly given me an old Danger Den block. ATM I have it apart cleaning it, but when I attempted to put my fittings in it I noticed it had a sloped channel. Let me illustrate the difference between it and my other blocks... This is a G 1/4 fitting.
OK so that's basically what the G 1/4 threaded holes look like.
How did people used to seal barbs in? did they use bigger Orings in those days? is it even possible for me to use this?
