Ok so I am build a PC for my friend (you can see the specs in the other thread I posted) but after deciding to set up a custom water cooling loop he decided he wanted to swap to a GTX 680 and we are going to be using the Cooler Master Cosmos II and here are the parts I have picked out.
Koolance CPU 370 CPU Waterblock Intel 2011, 1366, 1156, 155, 775 AMD AM3, AM2+, AM2 : CPU-370 Rev 1.1
XSPC Razor GTX680 Full Cover VGA Waterblock for NVIDIA GTX 680 Graphics Card : Copper
Laing D5 (Alphacool VPP655-T12) Variable Speed 12V Pump for 1/2" ID Tube : VPP655-T12
Koolance Laing D5 Pump Top and Reservoir Base Rev 2.0 : COV-RP450
XSPC RX Series 240mm Dual Radiator : RX240
XSPC EX Series 360mm Triple Radiator : EX360
XSPC 5.25" Dual Drive Bay Reservoir Multi Fascia : BR525DUAL
XSPC EC6 Non Conductive Coolant 1 Litre 6 Pack : Blood Red
Thermochill 1/2" ID - 3/4" OD (13-19mm) Flex Tubing : Clear (8 Meters)
1/4" Thread Compression Fitting for 1/2" ID - 3/4" OD (13-19mm) Tubing : Black Nickel x16
Phobya G-Silent 120mm Case Fan 1500rpm Red LED X8 (5 For Radiators 1 for exhaust)
Bitfenix 200 x 200 x 25mm Spectre PRO Black With Red LED Case Fan : BFF-LPRO-20025R-RP (Front of Case)
XSPC Razor Asus Rampage IV X79 Motherboard Waterblock Set
Now what I was wondering was. Will the 2 radiators be enough to cool a 3930K, the Rampage IV Extreme and a GTX 680 with the ability to be overclocked. and can you guys just go over everything just to make sure everything I have will work properly because doing a massive loop like this, its my first time X_X.
Thanks
Thanks
