Shikarikato
Components:
900D
Maximus 5 Formula
3770k
2x GTX 680
CORSAIR Dominator Platinum 16GB (4 x 4GB )
Western Digital WD Black 2 TB
840 Pro 256 GB
AX 860i
Water Cooling:
XSPC Raystorm CPU Block
XSPC Razor GTX 680 Block
MCP655(D5)
RX480
Bitspower Water Tank Z-Multi 250 Inline Reservoir
Does this look good or should I get more radiator coverage? I was planning to mount the rad in the basement to have it look a little cleaner but as with the size of a 900D I can mount more in the roof/front. My only issue is the CPU - Res connection and I'll assume it'll look pretty bad with such a long hose. Any suggestions?
900D
Maximus 5 Formula
3770k
2x GTX 680
840 Pro 256 GB
AX 860i
Water Cooling:
MCP655(D5)
RX480
