Water Cooled 400R
Overclocker55
So I already showed my rig off in the gallery but I have plans to water cool it. I already have a buildlog going on another site but I'll make on here too!
Current Specs:
In My Sig :cool:
Water Cooling Parts:
EK Supreme LTX Intel CPU Liquid Cooling Block -Ordering
PrimoChill PrimoFlex Advanced LRT Tubing -Ordering
SwiftTech MCR220-XP 240mm Radiator -On It's Way!
XSPC X20 750 Pump/Res Dual Bay -Ordered
6X Monsoon Free Center Compression Fitting White -Ordering
Black Ice GT Stealth 120 Radiator - Ordering Next Month
XSPC Razor nVidia GTX 680 Full Coverage VGA Block - Ordering Next Month
First Pic ( Will have the loop like this until funds for the 680 come in )
Second Pic Is The Final Build
Stay tuned for updates as my rad is coming in this week and waterblock next week! ^_^
Looking forward to it! I have a 500R myself and I'm always interested how people do their water cooling builds in the Carbide series cases because there isn't an awful lot of room to work with.
is this going to be an overclock rig?
starting with a CPU loop is fine, but just adding a 120 whatever, isn't really a solution
for cooling the CPU/GPU.
to properly do an overclocking CPU/GPU loop, you need surface area, but the case
is limiting this (other than going outside the case - blah) you might wanna look into
relocating or discarding the HDD cages and mount a decent if not beastly 240 in the
front. but this will kinda clash with the mega finned MRC up top. so different fans
will not perform well enough to keep a good headroom. two regular 60mm rads
can cover a medium OC and GPU, but those will have to be some great rads.
AlphaCool XT/UT, XSPC RX, HL SR1. low fin per inch, low-low fan speed (600-1200rpm)
the 750 pump will last a lil, but look for an upgrade when adding the GPU to the loop.
Well I might just go ahead and water cool my gpu and put my stock cooler on my cpu for now. I also own a HAF X so when It's time to water cool everything I can get a bigger rad for it.
