RecoilProduction
i've seen the red build before too but its both done nicely! both different kind of ideas but with the same concept and i dont see any harm in it,i would prefer yours in way of tubing cause its done much cleaner but i love redbesides that,awesome job dude!
Thanks a lot man. Yes, I wanted to keep the loop as simple and short as possible, and I also decided that I could fit the radiator on the board, instead of having it sit on a shelf somewhere.
It is mounted about 5 cm from the board, but that is plenty of room for effective airflow, aso I am pretty happy with the setup.
