VRAM Useage tests
Didn't see any ARMA 2 yet
well here you are
Game Engine - Real Virtuality 3
Game: ARMA 2 - Private military company (theres about 6 variants of ARMA 2 all are identical except the missions I own/play all)
Settings: all set to highest ( should be noted this game is terribly coded and is 15-20fps at these settings on my spec normally I play on mid settings for a solid 50fps no real visual impact)
AA-8x
Texture Quality - Very High
Video Memory - Very High ( not sure what this does or how it effects anything but saw no difference upon changing it)
Terrain - high ( no very high preset)
Shadows - Very high
Visibility - 10,000 (ranges from 500-10,000
Objects Detail - Very High
HDR - Very High
Postprocess Effects - Very High
VRAM usage 900-1000mb (never saw it go above 1,000)
GPU - 1x GTX 570 1.28gb
Resolution - 1920x1080
I still have no clue how to post sceenies so unfortunately can't provide visuals.
LysOl , just run Fraps in the background, and press F10 when you want a screenshot to save , than you gotta upload those photos usally found at c:/Fraps/screenshots to a photo hosting site, once they are there the site will make a IMG code, just copy the IMG code and paste it into your post.
I use fraps because I find it to be the easiest
I use photobucket so host the photos, it resizes them automatically, but it does have a size limit.
simple easy to understand...aint it
