7970 Lightning
what program u use to get higher speeds?, it does look weird tht i got more fps, but it could me hitting the cliff in power/mhz
power as in volt/amp, you do use catalyst 12.3?
At the moment this is my stable clock/volt settings. And yes i am running AB12.3
As you can see by the results theres not that much of an improvment. Im goin to stick to a lower clock that is a lot cooler and i only loose 0.5 of a frame.
awww but anyways those are great numbers, but bit sad u couldnt get more out of it :/
i wish you good luck!!
id say memmory wont do alot to fps but i might be wrong, im just new to this tho.
and minimum fps is cpu based some i do believes
im running 64bit windows 7 ultimate, works fine for me.
Ohh ok yeah i might read wrong on first page, u said msi afterburner didnt work in 32 bit, i might read wrong
i might have another 7970 in may to put in my pc, ill do benches if i do get
That is still super impressive. I remember you telling me your average frame rate in BF3, but I can't remember what you said. I think it was above 70, but just to clarify would you be able to run a BF3 benchmark (both stock and OC'd)? No worries if you can't though
Since you can not run benchmarks on BF3 i ran FRAPS for a few games when playing online . The results are as follows.
Metro: Average- 86 FPS Highest- 123 FPS Minimum- 30 FPS
Seine Crossing: Average- 74 FPS Highest- 112 FPS Minimum- 39 FPS
Caspian Border: Average- 69 FPS Highest- 92 FPS Minimum- 41 FPS
Wake island: Average- 71 FPS Highest- 105 FPS Minimum- 9 FPS
All these games were played in one sitting spanning 3 hours. This is with stock clocks with everything set to ultra.
Overclocking the card you see a light difference but not much. I ran the same maps OC @ 1170 on the core 1600 on the mem, There is a difference of 2 to 5 FPS but that could just be where i went on the maps or how long the match lasted. (Well within the margin of error)
Those are awesome results indeed, thank you
. The 7970 is truly a beast of a card.
Sweet results specially loved the Unigen Heaven Score.
and keeping the temp at 65C is more than impressive.
Koodos for the Review.
And MSI for the lightning series.
Now we will just have to wait for the MSI Thunder.
Nice card mate, debating between this one, the Asus 7970 DirectCU II TOP and a GTX680 myself.
At the moment the Asus 7970 is the cheapest and quietest solution so I'm leaning towards that.. but I'd love to be able to overclock the sh*z out of a 7970 lightning
Wow that card is sexy. I want...bad. Any chance of you uploading some pics of the card powered up? The back plate specifically. Just want to see what it looks like
great review, has made my mind up between this and a gigabyte windofrce 7970, now just need to find 400+ quid from somewhere................!!
