Hello guys
Ive overclocked my i7 a little bit more to 4.2 ghz@1,296V but i noticed that the minimum core volts on 1600Mhz [speedstep] jumped quite a little bit higher [from around 0.89V to 1,05V] which is slight overvoltage for 1600mhz step. So my question is where in Asus uefi do i turn this back to normal. Its so stupidly designed - i just have few diffrent 4-5letter acronyms with voltage settings in them, without any freaking explanation whats so ever, so iam not sure which one should i turn down to make low frequency voltage lower.
Also strangely Temps jump quite rapidly when i run wPrime from ~20degrees to 50 degrees within 2 seconds then stay at max ~55 degrees Celsius. I think it is quite high for just 4.2Ghz oc and ambient temp 14C [i run my pc in my little basement server room ;P]
ps. any suggestions for the volts?
ps2 pll overvolatage disabled, loadline calibration disabled, max ECO settings.
