name='stuartpb' said:Check C:\Program Files and see if the Sidebar folder is within it. If there is, there should be an exe to start the prog up.If the folder or exe isnt there then it isn't installed.
Posted that on the first page matename='PV5150' said:Go to Program Files - > Windows Sidebar - > sidebar.exe (if it's there)
name='PV5150' said:Posted that on the first page mate![]()
