Choose the "earlier version of windows" or if you want to choose "windows vista." It's up to you. I would personally choose "earlier version of windows.
shiftlocked said:No problems with vista here althoug the 3d mark series doesnt work on the Pre RC1 builds that Im using.
Sounds like it wasnt picking up an ip address or dns settings if it was showing the ip address and not the name of the wbesite. You also ahe to run the network settings wizard to allow you access to the net as its locked down from the outset.
XMS said:Looking at your screenshot now Browney it doen't look like something from boot.ini - more like something that Vista has installed into the bootsector of your hard disk.
You could go into the windows recovery console and try fixing the mbr from there. I forget the command. I'll try and look it up for you.
