Video converters for youtube ?
Dicehunter
Resident Newb
I'd like to start uploading gameplay etc... to the tube but im unsure as to which software i should use to convert my videos with.
Any info is appreciated :)
Youtube has great processing in most cases, the only drawback from using 'raw' footage from gaming is filesize (the uploader is very slow in my experience).
Personally I'd run a very high quality H.264 pass on it just to take off the 'losslessness' then it should be a more suitable size to upload (and not 4GB per minute or whatever raw game footage is these days).
I don't have any particular suggestions for software per-se, as all the editors I use output through h.264 already.
Quicktime has a re-encoder you could try I guess? the quality usually stays quite high I think?
It was just to reduce file size more than anything else, 264 has nice filesize for the quality, then at least the clips are archivable locally... ?
Fairy snuff, I use a mac for most of my video'y stuff so tend to steer clear of wmv's personally. :)
I'll let your greater youtube experience take over here though :) What editing software do you use Tom?
Thanks all for the replys, in the end i went with Xilisoft's video converter, read a bunch of reviews and it seemed the best in the sub hundred squid category ^^
