Video card opinion.
Ty07allstar
After X-mas I'm may get a new Gfx for the new UT07 and some other games. Would it be better to get a new card or just wait till DX10 and get a DX10 card?
so unless u can afford the large price for a dx10 card, and also the upgrade to vista, i would say go ahead and buy now
also, what are you upgrading from?
How much will a DX10 card be? I would probably get one of the better ones so i don't have to upgrade for a while but i dont want to spend over$300.Preferably 250-275. Also won't the DX10 cards use a ton of power from the PSU? And how much will Vista be? Does the Vista RC2 support DX10 or only the final release will support it?
I don't think anyone knows what you will be able to get in a DX10 cardfor $300, but I am sure it will outperform what you can get today for the same money. I don't know about Vista, sorry.
I dunno if it will be "necessary" but games will start being fully supportive with DX10 fairly soon. If you only wanna play CSS then you won't be very bothered.
A 7600GT is a great little card to get, but DX10 cards will be expensive when they first come out.
If you're not going to be an early adopter then get a decent 7600GT or a 7900GT or even an X1900GT - you'll be pretty damn happy :)
I'm gonna wait till AMD comes out with something new ill get that and a DX10 card and Vista.
