VERY urgent help needed
boardy
Hi guys, just need to know 1 thing very very soon. Is it ok to fill the back heater pad section of the kit with DC4?
I'm swapping over mobos and my P4P had condensation there :(. I dont want my IC7 to die quickly so wanna make sure its safe, i only have DC4 tho, no PCB laquer, and it's all lying on my bed atm needing to go back together :rolleyes:.
Cheers
Boardy
Mate I didnt fill the back plate on mine but i did smear about 2 - 5 mm of dc4 on the rear of my socket and the track around it that the plate fits over but remember the seal string wont stick to the dc4 looool:D
Im glad u replied when you did mate lol, was about to fill it.
I'll do the same as you then lol, sounds like the safest bet
Cheers
Boardy
