I see all these projects going around, so I thought id like to do my own. I dont feel too happy about cutting visible holes in my super expensive Stacker 830, since the cost of that takes me weeks to save up, my whole computer took me forever, but its what I like doing.
I was thinking, since space is limited for things like rads, maybe its a good idea to purchase a small ATX or even MATX case, drill holes in the back, and install 2x 360mm rads in it? Aswell as a powerful pump and res, to store all my WC'ing gear.
http://www.ebuyer.com/product/122774
Something like that should be able to house 2x 360mm rads on the base with a bit of drill and saw work. Could maybe put the res to the side of the rad's and the pump can go after the res, its small enough. With the res in there it would be 100x easier to get teh water in/out then using it in my actual case because if i spill some its not going to fall anywhere near my hardware.
So, I was just wondering, even if its not worth it performance wise, anyone think its worth a try? Could be a nice fun project hehe. Lots of ppl spend all their money on hardware but I think its when it comes to modding, you really make your rig your own.
With a bit of modding and blue coldcathodes it could look pretty sweet I think. Would prefer to use a black one for blue lights I could probably find one somewhere. Would need a powerful pump but say it moves 1500LPH it should be ok to pass from one machine thru all that right?
http://www.watercoolinguk.co.uk/catalog/product_info.php?cPath=37_73&products_id=376
Would probably use 2 of those rads, I have 5x hiper 60cfm 20dba fans atm they are pretty silent, only one thats loud is stupid motherboard southbridge cooler which im replacing soon with passive cooling. I could jsut buy another hiper fan for the rads, bean meaning to replace my case ones with blue LED ones for some time.
http://www.watercoolinguk.co.uk/catalog/product_info.php?cPath=77_74&products_id=387
And that pump looks best, on max it should be ok.
Waiting for input.. havent done any case modding before lols..
