jamesriley94
Hi,
Made an order from specialtech that came in this week.
The order was for a watercooling set up for the CPU with the waterblock, rad, res and pumps, along with all the alphacool fittings. Also there were 2 bitfenix fans with the order.
Now,
1 of the alphacool fittings has clearly been used. They all came in their packets, but this one had a cut through the plastic, and under close look of the fitting itself, if has the watermarks on the inside which surely shows it has been used.
Also, one of the Bitfenix fans is the same story. Both came in the boxes, one came with the screws and the lighting adapter cable, whilst the other came with no screws, no cable, and from closer examination of the fan itself, the screw holes in the fan have already been threaded, meaning screws have been put in, so it has already been used.
Overall, I'm not particularly happy about this. If it was the case with the waterblock or a big part I'd have sent it back, but 1 fitting and a fan are hardly worth the postage.
Last week also, I got Mushkin RAM from Aria. he story here was the same as with the Alphacool fitting, with the sliced open packet, but obviously with RAM there's no markings to suggest it has been used, but I hardly think anyone would have made the effort to open a pack of RAM just to look at it.
I just dont think it's particularly good of any company to do this to their customers. Maybe list the product as open box and sell it for £1 cheaper or something, but I'm sure there are laws about this? It's not exactly worth the effort to make a complaint to trading standards, but I thought it was worth a small forum rant.
Anyone else had the same experience?
Anyone think I should complain?
Kind of doesnt do themselves any favours as I'm less likely to order from these companies again. All just seems to be short term profits these days and no long term goals.
Now,
