M Metalboz New member Apr 23, 2012 #1 Does anyone know where i can get a USB 3.0 header converter for Sabertooth Z77? Hate having the USB cable from the 600T front panel running over the top of my GPU and out of a blank PCI slot into one of the external USB ports.
ruthless_villain New member Apr 23, 2012 #2 http://www.specialtech.co.uk/spshop/customer/Bitfenix-Internal-USB-30-Adapter--BFA-U3-KU3IU3-RP-pid-13747.html there you go, should work fine
M Metalboz New member Apr 23, 2012 #3 Ruthless said: http://www.specialte...-pid-13747.html there you go, should work fine Click to expand... Cheers
KING_OF_SAND New member Apr 23, 2012 #4 Lian-li makes one that is not a cable. http://www.amazon.com/2-Port-USB-3-0-Female-Adapter/dp/B005AJX9MW
ruthless_villain New member Apr 23, 2012 #5 KING_OF_SAND said: Lian-li makes one that is not a cable. http://www.amazon.co...r/dp/B005AJX9MW Click to expand... bitfenix one will look tidier though wont it?
KING_OF_SAND New member Apr 23, 2012 #6 Ruthless said: bitfenix one will look tidier though wont it? Click to expand... Depends on what you have plugged in. If you plan on plugging in 2 nice looking USBs like corsair flash voyager with the blinking blue LED, I would think the Lian li one would look nicer. but for external USB the bitfenix would look nicer.
