Urgent Help required re: new comp build
purplemonkey
Hi all
I'm heading over to the states on Friday and will be picking up a few new components:
Looking at:
E8600 Processor
Mobo - Undecided (help required) Thinking P5K Wifi
Ram - OCZ Reaper 1066mhz 2gb
Graphics - 8800 GTS
Raptor 10k 150GB Sata Drive
Thinking a 650w psu to drive that lot
i'll be running Vista Ultimate 32bit
I'll be looking to buy from Newegg.com but can anyone recommend any good US online stores to buy from that might be cheaper?
Cheers guys your a big help!!!
Most of the shops out there are fairly competitive.
Just don't get caught coming back through customs mate or it's time to fork out lots of cash :(
ED
I only use them and TigerDirect really. There`s ZipZoomFly (not used them myself).. Check some stores like CompUSA/Fryz for in-store deals too.
Thanks for the tips guys!
I believe you're allowed a £300 allowance which i won't exceed customs wise
what d'u think about the p5k wifi to go with the e8600?
Right change of plan slightly!
going for an e8500 and saving $100 bucks!
What do you guys think to the 8800GTS (G92)
I'll be using this comp for office work and Flight Sim X and thats the only game i'm looking to play.
I could stretch to an 8800 Ultra if its going to make a huuuuuge difference but i heard FSX is more about processor power over graphics cards
right final question really!
10K Raptor 150gb for $174.99
or
250gb Seagate Barracuda drive for $59.99
Does the 10k drive give a $110 buck performance gain?
By the way... You going to see family or staying in a hotel?? If you're staying in a hotel, those shops wont send to one. Tiger Direct wont accept international credit cards wither.. Not 100% sure on Newegg.
thanks for the info guys!
I'm still concerend over which mobo to go with for the e8500 can anyone recommend one or will the p5k wifi go well?
cheers guys!
another question opps
Will any parts conflict with a UK PSU?
thanks for the heads up about the international credit card issue i'd have to check that!
cheers
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130090
at only $199.99 am I missing something? Seems like it would be worth the extra 20-30 buck jump in price over a g92 8800GTS
Final spec is as follows, off on Friday afternoon so comments welcome!
Mobo - P5k premium
Pro - e8500
Mem - OCZ Platinum 1066 DDR2 2x1GB
HD - 250GB Barracuda
OS - Vista Home Premium 32bit
PSU - 500W
Case - Undecided
Sound - Xfi XtremeGamer
Let me know whatcha thinks
Many thanks for all your help guys much appreciated!!!!!!!
Ouch $861!!!!
little tip don't have any price tags or receipts or customs will make it expensive, i just came back and luckly I landed very eary in morning customs was still asleep LOL:D
