First i would like to ask if anyone would like to swap 5 Antec 120mm fans with blue leds. I just received my case, a antec 1200 but i am customizing evrything with red, as i dontlike blue, i will swap the 5 antec fans for 5 120 Xilence fans, the red ones.
2- I no idea what is happening with my water cooling system. The mobo cooling is kind of rusting before i set it up, no idea why, its being kept in the box, so very few chances of humidity. Is there a way to ask SCAN to give a new one, or do i have to ask directly to asus tek?
Problems -> The connection in between the barb and the GPU card is leaking all the time, on both block sides. I have tried without plummers tape, with a little bit, with a lot, and also different o-rings tickeness too. By the way, i also tried different barbs, and nothing got better. I did not tight it to much either, it is just firm as it should be, firm and secure. Can someone help me, please!
3- There are lots of bubles and foam on the loops, specially on the resevouir. Its really weird, i never seen a water cooling system with so much foam.
PS - I did not add anything to the coolant, the coolant used is a red Feser F1 coolant.
Anyone one have an idea why is the chipset water block rusting like that, if that is rust i mean. I did not loop the chipset block from the striker II extreme, because i dont want the others to get contaminated with whatever that is.
Please look at the pictures.
Regards
Denis
FOOOOOOOOOAM
Regards
Denis
FOOOOOOOOOAM
