upgrading my rig
jasper1881994
hey guys what do you think i should be upgrading on my system
specs:
core 2 duo e7500 3,8 ghz
xfx hd radeon 4890 stock speed
2 * 2 gig ddr3 pc3-8500
msi p45 diamond
coolermaster 630 watt real power
2* 320 gig hard drive
Depends what you use it for, if it's for gaming a new graphics card is going to give you better performance and if it's for video editing, music production or photoshop then the CPU. If you do just upgrade your graphics card though your CPU might bottleneck it so if you can afford it do a full upgrade, motherboard, CPU, GPU and RAM.
i'm a gamer i so i will be gaming a lot
Upgrading your graphics card would be the best thing to upgrade, a 6850/460 would be a good upgrade and if you want to spend a bit more a 6870/6950/560 TI.
For gaming the graphics card is the most important single upgrade to look at! I would recommend a overclocked edition GTX 460, performance wise for the money its probably one of the best cards there is on the market. You've got the power supply to handle it at least!!
this is what i'm thinking to do:
buying a
amd 1090t
asus crosshair 4 formula
corsair 4 * 2 gig pc12800 ddr3
xfx radeon hd 6870
Just get 4 gigs of ram instead of the 8. Unless you are doing excessive rendering/video editing there is not much of a point having that much ram.
