Korreborg
Member
Hey guys/girls
Swapped my old itx build for 7900x (delidded), asrock X299E-itx/AC and 32gb of 2400mhz ram.
I'm a gamer, so not the best combo, but I have always wanted a high end bulid
Then, to get a better gaming experience, I want to OC. And do I need faster ram?
Options for MB:
1. Get the bitspower monoblock for the itx board.
2. Get a ATX MB and a monoblock for that.
Options for ram:
1. Keep current MB and 2400mhz quad channel ram
2. Swap current for faster ram, maybe even dual channel and only 16gb? Will it make a difference.
3. New MB, and thereby new ram. Again quad or dual channel.
The question is, what to do will faster ram make a difference? And will a bigger board make OCing easier/better temps?
I have a 280mm and 240mm in my case. And have just bought a 400mm to mount under my desk and the have it with quick disconnect fittings. I'm all in for quite.
What would you guys/girls suggest?
/Korreborg out
Options for MB:
Options for ram:
/Korreborg out
