bloodthirst
Response Times
In order to achieve the color on a pixel in an LCD panel, a current is applied to the crystals at that pixel to change the state of the crystals. Response times refer to the amount of time it takes for the crystals in the panel to move from an on to off state. A rising response time refers to the amount of time it takes to turn on the crystals and the falling time is the amount of time it takes for the crystals to move from an on to off state. Rising times tend to be very fast on LCDs, but the falling time tends to be much slower. This tends to cause a slight blurring effect on bright moving images on black backgrounds. The lower the response time, the less of a blurring effect there will be on the screen.
if you have any questions just ask
