paulstung
In my new build I'm re-using my koolance PMP 500 pump, but to control it i either need the controller unit from Koolance or a fan controller with 32w or more on each channel, I'd rather not go either route as ther isn't muh room in the dead Silence.
So I had a thought, we are all used to changing the pins around on a Molex connector for fans, to lower the voltage, would this be possible with a pump ? With only a cpu loop, the power of the pump isn't needed.
In my mind it would be ok, if anything the pump just won't work, if anything over volting is were there will be problems. Am I right, or completely of track and in China ? Cheers guys.
