Ultraviolet
Endstadium
Here it is the bulid log to my purple Fractal Arc. I have build it in two main steps. The first was with only a cpu water cooled loop the second one is compleatly water cooled.
The System is at this date compleatly builded and runing. i will upload the compleate log when i find the time to make it.
PSU & CASE 1
Thats the standard Fractal Design Arc Midi Tower.
The frond and top part are easy ro remove and the mash is easy to remove too. So ic tooked the mash parts out spray painted them purple and put them back together.
I sprayed all the inside of the purple and sleeved the cables from the case black and purple.
Painted all the fans (Fractal 140) alsow purple.
Made the cut outs in the side pannel and fixed a acrylic windo with double siedet tape
thats the raw PSU
sleved all the cables i need in purple and black
pantet all the visible logos alsow purple and fitted it in the case
so thats part one... hobe you liked it.
Personally I'm not really a fan of that color, but you've managed to get me hooked on your project. Looks pretty good and I want to see more of it =)
Are you going to modify/paint some of the hardware as well? Like the motherboard or graphics-card for example.
thanks for the nice comments
looking good, keep us updated
the rig is at this time "compleatly" buildet and runnes sind decembe 2011. I try to post the log if i finde some spare time
.... Are you going to modify/paint some of the hardware as well? Like the motherboard or graphics-card for example.
my mainboard, cpu and gpu are watercoolt at the moment (build log follows), but i dident mod the parts more than put the water blocs on them. im actualy planing a new build for the summer or lets say not a new buld more a makeover and i hope im able to mod some parts at the new rig
When something looks so effortless, you appreciate how many hours of work have gone into it to make it so.
The curvy window is brilliant.
Looking forward to your next batch of photos.
Build log Part Two.... first Loop & hardware
Here a quick overview over the hardware i used to build the rig.
My Amd Fx 8120
My Gigabyte GA-990FXA-UD3
My Asus 6970 DCII
the first fitting of the hardware without CPU and water cooling loop.
some parts of the water loop
bay res
cpu block
fans and radiator
pump
the fittet loop
close up loop
the closed system
Part 3 final mod to two dual 120radiators and a compleate watercooled system
some slieght case modifications.... drimmel out the buttom drive cage and fitting a radiator grill in the floor of the case.
old case layout
radiator grill
new case lay out
closeup... fitted rad grill
new cooling parts
mainboard blocks
gpu block
gpu ram heatspreders
some nerd porn
"nude" GA-990FXA-UD3
"nude" Asus 6970 DCII
wasnt sure if i coud get rid of the thermal compount without damaging the pcb so i left some or it at the pcb
fitted waterbloks
GA-990FXA-UD3... the Block for the south brige dosent fit in the set from EK so i went on with the old heat spreder
Asus 6970 DCII with block and ram heat spreder
new phobya fans
put all the parts together and filled up the loop
some closeup's
the compleate and closed rig
thats my "comprlated" rig
sorry for the quality of some of the pictures.. i hope i find the time to make som better ones in the near future
