Trouble loading certain websites
Azurite
Cant watch arsenal.com, photobucket, Corsair and a few other websites. Getting error 324 with chrome. Using IE doesnt help either. So what do you think this is? got a fealing that it is the broadband connection with certain countries that are faulty but im not 100% sure.
Getting Error 324 (net::ERR_EMPTY_RESPONSE). This happens ahen i go to Arsenal.com, Corsair.com. Photobucket is also behaving odd. Its like its half loaded.
It might be a problem with your ISP not being able to make contact with the websites. I'm not 100% sure though.
Yeah that was exactly what i thought also. Its happening when i use IE also, so its not only chrome who have this issue. Well, i hope it gets sorted soon.
Is there any news of problems on the ISP's website? You might be able to find out if there are other users having similar problems.
Are you using the DNS provided by your ISP? If so, try using Google's DNS or Open DNS.
Ok im trying to solve this now. I have the modem connected to the pc now and everything is fine. So the issue is with my new router...... looks like i must read trough the manual now and see what is causing this. The issue suddenly appeared after several weeks use with no problems.
Any suggestions?
Edit: Almost solved. I reset the router and now photobucket and a few more works. Arsenal.com is still not working....
Edit: Damm it!! im getting mad now. Ive installed newest firmware but still not fixed. Arsenal.com and speedtest are just two of the sites i cant get into properly. Im getting frustrated now. Think il just RMA it and try a new one. It worked fine in the beginning so why is this happening....
If anyone got some suggestions im happy to hear it.
I thing you might have to RMA, unless someone knows something.
Yeah this is hard to figure out. Theres so many abbreviations for network im not familiar with. I did find out that my IP is dynamic and that the router is set to get all this automnaticly. So it should be just plug and play really. I even installed newest formware and re-set it also, but the issue is still there, so i guess theres no other way than RMA it.
Omg 14 days and i need a new router. Im becoming a real router destroyer. Think ive had 6 routers the last 6 years. Im gonna ask the store where i bought it if i could have an ASUS RT-N56U or a LINKSYS E4200 instead.
I had the same problem with routers until I started using Netgear. Now I am just using the router provided by my ISP, which seems good so far.
Thats good. Tbh i have never experienced anything like this with a router before. My ISP doesnt have any wireless routers only modems so i need a good wireless router
Finally, Netgear have found out that their router is bugged, lol!! Only took 2 months! Cant believe ive wasted so many hours on a product that should have been shipped back to seller right away almost. I actually had to write Dustin.no a really hash mail explaining them what customer rights i have in this country. They replied to me and says that they will pay for the shiping back and also they will transfer back the ammount i payed for it. Its sad that companies are trying to exploit customers in this way. Netgear suport/dustin.no have both been PITA in this case so im not buing anything more from them
Im looking at these now, but havent decided what to get. Just want something fast and reliable Linksys: E4200, Asus RT-N53, Asus RT-N66U, D-LINK DIR-657 HD
