Craterloads
** Hi guys, just posting my build log over here to share with you all and hopefully receive feedback and suggestions on direction. I'm still in phase 1 of the restoration and phase 2 will be new the hardware stage. So will (copy paste) post progress of what I have done so far below and then update fresh from that point on. **
I came of across a system on eBay a few weeks go that was up for sale as spares / repairs, which caught my eye. Never seen anything like it and there isn't / wasn't much information about it online but it seemed cool and thought it would make for an interesting project. Having done many builds over the years whether they be small, large, water cooled etc i'm kind of bored with doing the same stuff with updated components, so this kind of project was perfect to get me motivated.
Here are some links to the system, not sure what its initial use was for but perhaps some sort of editing workstation.
http://web.archive.org/web/20040814221851/http://www.umdigital.com/product/p01_tra_400s.htm
http://www.gtrade.or.kr/buyer/product/TRAPEZIA-UM400.do?productId=C2007-0000006058&categoryId=C0402
http://umdigital.en.ecplaza.net/trapezia-um-400-dcd-system--64174-81150.html
Some quick specs
Ancient stuff but still cool, 4 GPU monster
Now as I mentioned when I got the system it was spares / repairs aka it wasn't working, been sat in a garage for a while it seems. So my first goal was to get it up and running to make sure there's something to work with if I take it any further. No point continuing if the screens are dead. So over the last few days I have been prodding, probing and diagnosing the system to figure out whats up with it (with the help of the guys over at badcaps, thank you)
Here are some images of the system as I got it
As you can see not in a very good state, absolutely filthy, had at least a dozen or so creepy crawlies living in there and I hate spiders. Thank god I had the sense to spray the entire thing with some Raid bug killer which just left me only having to vacuum up their carcases rather than having to set the house on fire
First things first, I photograph everything as there are way too many connectors and cables for me to remember what goes where. Tagged all cables and connectors with numbered labels and I can begin to mess with it.
So after a bit of prodding I've narrowed it down to a dead PSU, great that's something that would have been replaced and saves a lot of trouble shooting if that is the only issue. Only issue with that is the PSU is custom and has loads of custom connectors powering everything. For example the all the monitors are powered by the PSU off the 12v rails, something else is powered off a 5v rail etc so isn't a simple swop over PSU and test. So did a bit of bodging of all the connectors and my spare PSU to get it all powered up and tada she lives, well kind of anyway! So I know it lives to some capacity it's time to strip the thing every bolt and screw and take it apart and give it all a thorough clean.
All non electric stuff took a bath and got a good scrubbing, wiped everything down with isopropyl including all circuitry, dusty / oxidizing connectors and cables. Starting to shape up now and is nice all clean looking presentable. So put it back to a partially assembled state to test it further.
One of the screens was displaying an intermittent problem, which could have been serious, but thankfully was just a dodgy ribbon cable. So removed it and cleaned both ends and its socket, put back in and secured with some hot glue as the original tape and turned to chalk. Working as good as ever now.
One of the internal cables used to control all 3 larger screens had a dodgy connector (possibly done by me) which was a pain in the butt as is a JST connector and really finicky to work with. So settled on modding a USB 3.0 header, cutting it down to 5 pins and soldering the original cables over to it giving it a nice strong connection. Worked a treat and now got full control of the monitors. I'm happy with it but might change it later on, not sure yet.
Some quick specs
- 3 x 17" (1280 x 1024 @ 60Hz) Screens = 3840 x 1024 Ultra Wide Screen (115cm Wide with a nice curve)
- 8.4" Touch Screen (Should be great with Windows 10)
- T Class audio amplifier (Tripath TA2024)
- 2 x 3" Full range speakers
- Dual ODD Drives
- Memory Card Stuff
- Intel P4 3.40GHz HT Prescott LGA 478
- AOpen AX4SPE Max LGA 478
- 1GB DDR 400Mhz
- 3 x NVidia MX 440 SE PCI Graphics Cards
- ATI Rage Ultra 128mb AGP Graphics Card
- 460W Seasonic PSU
- 2 x Pioneer DVD Drives
