Too Many Keys
llwyd
I bought a Saitek Eclipse yesterday and it came with that command pad they do. 9 extra keys, with two additional modes means i have an extra 27 buttons to make use of. i doubt i will be using beyond the first 9 but thats still 9 more than i know what to do with. Any ideas? i was thinking binding them to css commands but i cant think what
name='browney' said:
Flash, nades
Yup, program the keys to switch and throw your nades and flashes then switch back to primary or secondary wep... That's what I did with my Pro Gamer Command Unit. Works out nicely.
you wanna give me the commands for that? :) i did try but i failed
All you have to do is record the macro of how you would do it manually. Switch to nade, fire, switch to primary weapon. It's not that difficult, lol.
and i would do that how? its only easy if you know how lol
It would be something like (i haven't done this in a long while, but)
Switchweapon flash;
wait;
wait;
wait;
Fire = 1; (not 100% sure here)
Fire = 0;
wait;
wait;
wait;
Switchweapon M4. (you could probably set it to weaponslot so you don't have to have a specific weapon).
I haven't used CS:S for a while now. But you'd want something like that ;).
Switchweapon flash;
wait;
wait;
wait;
Fire = 0;
wait;
wait;
wait;
Thats a source script, for the G15/Eclipse software you have to record macros's of certain keystrokes. It's actually much easier.
You do have the software that came with the device installed dont you? From there it's pretty self explainatory on how to get it to work.
soo for me all i have to do is record the keystrokes on buying what i want to buy and it should work?
just been fiddling, turns out the SST softwere didnt install properly, just installed all the shortcuts :/ ive downloaded the latest version and im creating macros like theres no tomorrow ;)
