FarFarAway
name='FragTek' said:I may recruit your services![]()
I already have...XMS said he could take payment in kind
name='kempez815' said:I already have...XMS said he could take payment in kind
name='muffin said:Alright, I can see xms has a monoply in the sig making market here. Healthy competion is needed, and so I give you the left handed[/I'] paint sig![]()
name='sai_jao' said:lol those sigs rokbut ill stik wit mine for a while
muffin said:Well, the longest ever build, the quickest ever OS install...literally, blink and you'd miss it.
All parts workin fine (sorry frag) and now installing SP2
muffin said:Will do![]()
Up and running, AV on and network workin first time! Still got that stupid DNS error, using the IP to my ISP like xms said, and its running ok
EDIT: Well this is gay, idle at 40C
EDIT 2: Load jumps around between 47-48-49
name='XMS' said:Thats running a bit high!! Have u got it on the right voltage for ur mobile?
muffin said:Its not mobile...its a desktop CPU, 3000+ Newcastle. I think I bodged putting the Ceramique on![]()
Ack, water cooling at the end o the month, pick me out a good setup for <£170 xms?
XMS said:My setup+amd waterblock=£170
If not, take a pic of ur rig and send it to me.....what watercooling setup you get heavily depends on where you can stick it
muffin said:Cheers guys, tis a bit messy though, that was right after I put it together and I not got the cables squared away![]()
And xms, hold on! Space is not an issue! I had the brainwave of all brainwaves at work tonight...hardly got any work done I was thinking about this so much
I'm gonna go for that Swiftech MC650 pump thingy, a Swiftech water block and a dual 120mm radiator![]()
FragTek said:Now that's some orgasmic shiznit right there buddyEnjoy the power of extreme watercooling
Pix when u get it all!
muffin said:Yup, I'm lookin at ~£180 ($344 US) for the gear, plus whatever it takes for the supplies to make my little project which is gonna be sweet if I get it right. Could take a while though, no telling what it is till I've finished![]()
By the way, going for an XSPC Zern A64 waterblock, as Swiftechs are proving hard to track down. The rad will be a BlackIce Pro 2, with 4x120mm Thermaltake Thunderblades on it. A Swiftech MCP650 pump and 1/2" fittings all round.
