Thinking about a case change
ok currently im using an antec 1100 with a h100 cpu cooler in it, however the 1100 was not designed to house the H100 very well so its kinda just sitting inside my case.
Ive been looking at the Corsair 600T as a replacement for the fact that it has the space at the top to mount my H100......
what do you think or what else would you suggest?
Cheers
Niall
I have the Bitfenix Shinobi XL and I love it, although I'm not sure how it would look with a H100 in it as it can fit a 360mm RAD in the roodf :P The 600T is a good choice also :D
I'd never recommend a full tower case unless you're watercooling / have SLI or Crossfire or something.
So mid tower...
600T, 650D - both good choices, although a little expensive IMO.
Maybe the Phantom 410, or Corsair C70? Fractal R4 with the windowed side panel maybe?
I still love the CM690II, as it's a great case for the price. I personally can't see it being worth over double the cost of the CM690 to get the 600T, but they're just my thoughts.
Can't really go wrong with any of the ones mentioned above.
